Gasoline smell; where is better to start inspecting ?
Old Jun 5, 2019 | 12:32 PM
Externet's Avatar
Question Gasoline smell; where is better to start inspecting ?
Only at times, unrelated to low or high fuel level in tank, smells inside and outside when it wants to. May go days without smell.
Old Jun 5, 2019 | 12:42 PM
zuke's Avatar
If you are a fairly new owner and this has always been there, I would look at the gas pump seal. I had one where the PO had screwed up the installation and made a potential bomb out of it. He wasn't even a muslim, just a bad mechanic.
Old Jun 6, 2019 | 06:32 PM
Extinct's Avatar
I would look for leaks at the fuel line at the back of the manifold. Should be much stronger smell if you open the hood and sniff around by the ignition coils. If that is it, it is a potential fire hazard if you get a spark plug wire insulation issue that causes a spark to the firewall (common).
Old Jun 6, 2019 | 06:49 PM
XRAD's Avatar
I had that. Turned out to be a leaky intake manifold ( I think, because it went away after new gaskets). Only sometimes the smell would enter the cabin....
Old Jun 7, 2019 | 07:12 PM
Extinct's Avatar
Probably leaking at the fuel line, but they had to disconnect it to get the intake off and then reseated it when the gasket was done.
JabaThaHut
Dec 30, 2015 06:42 PM
Thomas Lane
Mar 26, 2015 10:01 AM
Brian Lipka
Apr 8, 2012 02:16 PM
newworld
Nov 28, 2011 12:00 PM
DiscoGal
Oct 17, 2006 03:36 PM
