Gauge set doesn’t work when it’s cold
Old Mar 15, 2019 | 11:56 AM
Kadin Wallner's Avatar
Default Gauge set doesn’t work when it’s cold
Sometimes in the morning when it’s really cold the gauges and lights don’t work until I drive for a bit and let the battery charge. Is this normal? If it isn’t what could the problem be?
Old Mar 15, 2019 | 02:21 PM
Richard Gallant's Avatar
Could be a weak battery, cold will bring out the worst in them. Does your truck turnover strong or a bit weak ?
Old Mar 16, 2019 | 10:57 AM
When it’s really cold it takes a little bit longer and it actually takes a couple turns with the key to get the starter going. I got a new battery back in August
Old Mar 16, 2019 | 01:38 PM
Sounds like one of 3 problems,
  • your alternator is not supplying very good voltage, so your battery is getting a marginal charge
  • your battery has a poor Cold Cranking amp rating or is just not very good
  • You have a drain somewhere
My suggestion is take it out for a good drive then disconnect the battery overnight, hook it up in the morning and see if the truck starts normally of it does it is most likely something draining your battery. If not it is the battery or alternator, you can check the alternator and battery with a multi meter
Old Apr 6, 2019 | 11:41 AM
i actually put a new alternator back in November because it stopped working and I got stranded. So hopefully it’s not the alternator. It’s a Walmart battery so it could just be a crappy battery. I have a subwoofer but it doesn’t turn on until the stereo turns on. When I put the stereo in I didn’t connect the constant(or whatever it’s called) wire so it doesn’t give it any power when my car is off. That little digital clock up front stays on but I doubt that could be draining the battery THAT much. The clock doesn’t light up like it should either but I’m not worried about that. Is there anything else that could be draining the battery?
Old Apr 6, 2019 | 12:37 PM
User's Avatar
Wait wait wait wait
My turn signals don't work in 20 or so degree weather until the cabin is warmed up, I assume it is the grease in the contacts
Old Apr 6, 2019 | 11:27 PM
Saturnine's Avatar
Yep, i get that as well. Dexol is what i use to referb vintage guitar amp pots, ill probably give that a whirl
Richard Gallant
May 21, 2019 10:23 AM
djfoxxy9
Jan 9, 2017 11:06 PM
xaviercampos
Mar 13, 2015 11:14 AM
anaccash
Jan 19, 2012 07:45 PM
xtina01
Nov 5, 2011 10:18 PM
