Gbr drive shafts
Old May 17, 2012 | 09:33 AM
30more's Avatar
Default Gbr drive shafts
Going to put my HD GBR drive shafts in after work. The rear 1 comes with a flex coupler conversion,does anyone know how to install this I haven't got it yet to look at. Just trying to be prepared don't wanna run into any road blocks. Anything else I should look for?
thanks Joe
Old May 17, 2012 | 09:37 AM
bullcrew's Avatar
thanks Joe
Just did mine there's a link on discoweb under the tech section.
Old May 17, 2012 | 02:29 PM
bosshogt's Avatar
The tuff part at least on a 03/04. Not sure if it different on earlier models, is removing the centering pin, on the rear pinion. It was a bear on my 2003. Here is a video and the solution I came up with. Took some thinking and craftyness with a 3 arm puller and 3 3/8" 3" socket extensions.
Discovery II removing pinion - YouTube
Old May 17, 2012 | 10:26 PM
30more's Avatar
[QUOTE=bosshogt;320562]The tuff part at least on a 03/04. Not sure if it different on earlier models, is removing the centering pin, on the rear pinion. It was a bear on my 2003. Here is a video and the solution I came up with. Took some thinking and craftyness with a 3 arm puller and 3 3/8" 3" socket extensions.
So I tried this approach, I broke 1 of the bolts that I was using to back it out man is that thing in there.. Luckily I was able to get the bolts back out and put my old rear drive shaft back in. Going to try again tomorrow maybe use some pv blaster. I will have better luck hopefully. Any ideas on how to make this easier?
Thanks for your time!
Joe
Old May 17, 2012 | 11:51 PM
FlyingZebra34's Avatar
That guy in the video is just great
Old May 19, 2012 | 07:55 AM
30more's Avatar
Got it!!
Thanks for the help!
Joe
Old May 19, 2012 | 08:41 AM
Don't forget to grease the new shafts, including both slip shafts then do it at least twice a year to maintain them.
Old May 20, 2012 | 08:42 PM
bosshogt's Avatar
Glad you got it out. It looked like when I removed it the factory had used loctite. I used Deep Creep by Seafoam. It helped a little but that pinion was just galvanically corroded in there.
I like to have some fun when I take off SOB bolts.
LRJtech
Mar 21, 2015 03:30 PM
Drillbit
Jan 28, 2015 06:38 AM
TRIARII
Jan 27, 2014 01:38 PM
nychaze
May 14, 2013 04:31 PM
Big Jim Swade
Dec 16, 2011 10:47 PM
