Gear from 2000 to 2003 d2
Old Dec 8, 2024 | 09:11 PM
D2disco's Avatar
Default Gear from 2000 to 2003 d2
Hello, i recently moved the gear from my 2000 disco to a 2003 disco that has traction control. I got the difflock to work, will difflock and traction work normal together?
Old Dec 9, 2024 | 10:11 AM
mollusc's Avatar
All Disco 2's have traction control. 2003 Disco does not have a locking central differential unless you change the transfer case, which I'm guessing is what you did.
Ideally you will want to change the SLABS unit to the 2004 model which will understand both the traction control and the CDL working together, but it's okay to stay with the SLABS you have and just be sure that you shift out of diff lock before you shut off the truck. There are tons of write-ups on this.
Old Dec 9, 2024 | 05:12 PM
D2disco's Avatar
Yes your right, i moved the whole transfer case from my 2000 disco to 2003. I probably wont be able to find the slabs in my country as parts are limited. I do appreciate the info you have provided. Lastly, the gear handle doesnt go left as much as i would like it too, can i just cut in the metal plate to allow it to move left more?
Old Dec 10, 2024 | 08:33 AM
mollusc's Avatar
You should be able to stay with the SLABS you have. I believe the only major issue is that if you start the vehicle with the CDL locked, there will be a traction control error.
Why can't you simply move the cover plate from the 2000 to the 2003?
Old Dec 10, 2024 | 10:05 AM
D2disco's Avatar
I sold the other disco and no longer have access to it. Didnt know this before hand.
Old Dec 11, 2024 | 12:20 PM
mollusc's Avatar
In that case, it should be fine to enlarge the hole so that the lever moves more.
Old Dec 11, 2024 | 12:22 PM
D2disco's Avatar
Good to know, thanks again.
Old Jan 20, 2025 | 07:38 PM
sstevensonm's Avatar
Default 2001 to 2003
is this an option? Can I move just the cover plate, or do I need to move the whole tcase
Old Jan 22, 2025 | 09:32 AM
mollusc's Avatar
To do what?
If you don't have a locking transfer case, moving the cover plate won't achieve anything.
davecason
May 26, 2015 07:23 AM
Dane!
Feb 24, 2014 05:41 PM
wilson96rr
Mar 14, 2012 06:27 PM
2000 DII
Sep 9, 2011 11:37 PM
03discoman
May 15, 2010 05:59 PM
