Gear Box front output flange
Old Dec 20, 2014 | 12:06 PM
diggerod's Avatar
Default Gear Box front output flange
04' gear box, should there be any play on the front output flange where it enters into the gear box? I'm hearing some kind of chattering noise, that I thought was coming from my front passenger side brake caliber. But after checking around, if I grab my front drive shaft by the rear where it enters into the gear box it is a little sloppy, not the u-joint but the actual flange. Almost kinda sounds like a bearing starting to go bad.
Old Dec 20, 2014 | 12:09 PM
diggerod's Avatar
Also this only happens when I let off on the gas and start to slow down. It does not make the noise when driving around.
Old Dec 20, 2014 | 01:29 PM
dusty1's Avatar
it should not be that sloppy and that decel. noise is indicative of bearing failure. i think you have pinpointed the issue
Old Dec 20, 2014 | 02:20 PM
diggerod's Avatar
Is that something the average mechanic can do, I need to replace front u-joints anyways?
Old Dec 20, 2014 | 02:27 PM
dusty1's Avatar
It can be a bear to remove, but doable. I didn't have a lot of trouble, but I had the whole case out.
Any mechanic should be up to the task
Old Dec 20, 2014 | 05:28 PM
OffroadFrance's Avatar
Dusty is right. RAVE page 41-6 shows the front flange and shaft components and the offending bearing.
It's best to drop the box but it may be able to be done insitu, don't know. Any good 4x4 mechanic should be able to replace the front bearing on a LT230 but probably better at an LR garage rather than a 'do it all' workshop.
Does sound like a bearing if it's noisy on the overrun. Don't leave it too long in case it breaks up in place and then your troubles will be multiplied tenfold.
Old Dec 20, 2014 | 08:38 PM
Lowest Bidder's Avatar
A new bearing has a very slight play. Like you can't see it move, but you can feel it move in your hand if you try to wiggle the drive shaft near the flange. It's very slight, almost not perceptible. It can be replaced with the transfer case in place. But you need the right tools. A garage with jacks, so you can get under the truck and work in a safe manner.
Remove the drive shaft first. Having the special tool is nice but it can be done with just two 9/16 wrenches. The slimmer the wrench the better. Then remove the nut holding the output flange in place. 30 mm socket I think. Then Pry off the seal and discard. Then using a strong pair of snap ring pliers, remove the snap ring keeping the bearing in place. You need good strong snap ring pliers, the snap ring is pretty thick. Once the snap ring is off, place the flange back on the shaft and put the nit back without tightening it. Fit a slide hammer puller with a suitable attachment on the flange. There's plenty of space where the driveshaft used to be, but be careful not to scrape your knuckles on the catalytic converter. With the right setup, the bearing is quite easy to get out. Once it's on your bench, use a puller to remove the bearing from the shaft.
Once the bearing is off, it's the reverse procedure to put a new one back in. Use a brass pin and a hammer to gently drive the bearing back on the shaft, and then the bearing and shaft back in the transfer case. put the snap ring back in place, then use the old seal to drive the new seal in. Clean the flange and put a light coat of oil on it, then put it in on the shaft. Tighten the nut, install the driveshaft, and you're done.
Old Dec 20, 2014 | 08:44 PM
Old Dec 20, 2014 | 08:47 PM
Oh and I forgot, the seal is there to keep the oil in the transfer case. When you remove the seal, the oil pours in your hair, unless you drop the oil first. Don't ask me how I know...
Old Dec 21, 2014 | 03:51 AM
Like it, cheap Brylcreem
Résultats Google Recherche d'images correspondant à http://24.media.tumblr.com/tumblr_m7qixzNmiT1qzsrxjo1_1280.jpg
