Gear box m & s light isues
Old May 26, 2016 | 09:40 AM
oppositelok's Avatar
4th Gear
Default Gear box m & s light isues
Firstly hello to you all as this is my first post on this site.
I am having issues with my gear box. I have a 2001 disco 2 and recently the gear box m & s light keep coming on and the box goes into limp mode.
So far I have changed to atf oil twice.
Changed the gear box filter and seals
Replaced the battery with a new red top optima
Changed the XYZ switch
Had the XYZ switch adjusted and checked on a diagnostic machine
Nothing has made any difference
However the gear box still keeps playing up. It only ever causes trouble when it's cold / first started and put into reverse; then it goes straight into limp mode.
The other issues and the most annoying one is some times it will not start due to the inhibitor switch I assume. Eventually if I keep trying it will start but then I will not be able to put it in revers until warm.
Any ideas to solve this would be great fully received. It has been surgested that I need to change the box wiring loom. However I wonder if it could be a voltage issues. If so any why I can check for sure before looking at changing the loom.
Many many thanks in advance.
Old May 26, 2016 | 09:50 AM
Charlie_V's Avatar
Form personal experience I suggest you first swap your battery with a known good one from another vehicle. See if it does the same thing at startup. I know you have a new battery but I'm not clear whether the problem went away when you put it in, or if it did okay for a time, or if it made no difference. If it didn't make any difference, disregard swapping the battery. I had similar trouble and it was a bad battery, but you might have a different situation.
And when you say it won't start are you referring to the engine or motion of the truck?
Old May 26, 2016 | 10:00 AM
4th Gear
Changing the battery made no difference. So far nothing has.
And by not starting I mean the engine, it just clicks as the inhibitor won't let it start. I have had it checked after and it shows a mis read on the xyz switch. But the switch is new and properly calibrated. It read correct in all gears even if wiggled in gear.
Old May 26, 2016 | 10:31 AM
NickAdams's Avatar
Double check the wiring diagram in Rave, but I'm pretty sure the transmission is wired to both the ECU and the BCU. Even with a new XYZ switch, if the connections at ECU are corroded, it will get bad data.
Before my scangauge quit talking to the ECU altogether, it would only work after I got the passenger footwell (location of ECU) warmed up.
Old May 26, 2016 | 10:33 AM
drowssap's Avatar
What is your voltage at idle?
Old May 26, 2016 | 11:09 AM
4th Gear
I Will check idle voltage tomorrow.
Does the gear box talk to the slabs and the under bonnet ecu then?
Old May 26, 2016 | 11:53 AM
mln01's Avatar
It's true that low voltage can trigger the flashing M&S lights but there are over a dozen transmission faults that can also cause the M&S lights to flash. I suggest that you get the transmission codes read so that you can accurately diagnose the problem.
Old May 26, 2016 | 12:47 PM
4th Gear
Ive had the codes read 3 times now. It only ever show gear box switch miss read
Old May 26, 2016 | 01:32 PM
NickAdams's Avatar
You might want to read my thread about scangauge not communicating with the ECU. I cleaned all my ECU connections with plastic-safe CRC contact cleaner (a whole can) and a nylon parts cleaning brush.
Old May 26, 2016 | 03:50 PM
Charlie_V's Avatar
This shows the wiring layout.
