Gear oil
Old Dec 26, 2018 | 02:03 PM
redwhitekat's Avatar
Default Gear oil
Going to replace my diff fluids soon on my 03 disco.
What are you guys using as far as synthetic vs regular Dino oil
Old Dec 26, 2018 | 04:57 PM
Best4x4's Avatar
I use Dino 85/140w personally.
Old Dec 26, 2018 | 09:34 PM
Stein's Avatar
I used synthetic 75w90. But seems like everyone on these forums use the thickest dino oil possible in these cars...
85w140 might not be best since your in a colder climate unless your axle is leaking or you just like driving 200kmh down the TCH.
I also replaced the plugs.
Old Dec 27, 2018 | 10:31 AM
Roustabout's Avatar
I have been using Redline heavy shock-proof. I've done multiple fluid changes and no wear issues. My truck now has 450000km on the clock.
Old Dec 27, 2018 | 12:38 PM
just curious is that all on the original drive train ? If it is that’s quiet impressive and shows how maintenance goes along way
Old Dec 27, 2018 | 01:08 PM
Best4x4's Avatar
My 02 has 237k and climbing all on the original drivetrain. Zero issues & it runs better IMHO than most D2’s with less than 100k.
Up in Canada I’d just stick with 75/90w or 80/90w.
Old Dec 27, 2018 | 04:52 PM
thats awesone for stock. I think a lot of people just neglect these trucks
Old Dec 27, 2018 | 05:13 PM
Best4x4's Avatar
Yep mine was very well kept by the previous owners. Dealer serviced & all LR parts (not all that important as some aftermarket stuff is better IMHO). But yeah I honestly never buy a LR with less than 100k.
Old Dec 27, 2018 | 08:59 PM
Roustabout's Avatar
450000km on the original drivetrain. I believe the original owner had the head gaskets done. I bought it at 175k and have not touched the head gaskets. Diffs and tranny are still in good shape - no noise or vibrations. Truck has always been well maintained.
Old Dec 27, 2018 | 10:47 PM
when you bought it did it have the 180 stat and we’re temps down or did you do all the tricks this board focuses on ?
I hope mine lasts that long. When I bought mine it only had 115,000 km but running at 220-225 degrees and ticking when hot, already had the gaskets done at 80000 km and had a few oxygen sensor faults running rich codes. After a month of tuning it up it’s running amazing
