Gear whine normal?
Old Jul 11, 2006 | 10:45 PM
Brad S1's Avatar
Default Gear whine normal?
Seems like the front diff or maybe the tranny whines... It's not loud, but you can def hear it, comes from just under and forward of the gear shifter. Is a little whine normal, I know my mustangs rear end has a decent amout of whine so I wasn't sure. Also what do you guys use for tranny and diff fluids? Do you add anything special? Thanks alot!
Old Jul 11, 2006 | 11:30 PM
Default RE: Gear whine normal?
Most Rovers have a small and common whine noise, so assuming your fluids have been changed and are full, most likely you have nothing to worry about.
Mike
Old Jul 12, 2006 | 11:09 AM
Landzu's Avatar
The Disco I's tranfer cases makes the noise.
Its the gear's and how they are cut, the Disco II's
have a newer transfer case that has the designation of Q
for quiet.
I use synthetic gear oil it gives me peace of mind.
Mike
Old Jul 12, 2006 | 11:34 AM
You might also want to go to a slightly higher weight gear oil, that will cut down on the noise and potenetial wear.
Mike
Old Jul 13, 2006 | 01:41 PM
Brad S1's Avatar
What type of gear oil are you guys using? While I'm at it, are you adding anything to the trans?
Old Jul 13, 2006 | 01:50 PM
ORIGINAL: Brad S1
I add some Lucas Transmission additive to the tranny, I use an 85/140 wait, GL6 rated gear oil to the t/case and diffs.
Mike
Old Jul 13, 2006 | 02:01 PM
Brad S1's Avatar
Mike you're really helping me out by answering all these noob questions, haha. Thanks a million, I'll be checking all the levels today as soon as the rain stops.
Old Jul 13, 2006 | 03:13 PM
Rainey day, probably a good day to be under the truck.
We had 3 good days of rain here in Denver last week, blew my run I was looking forward to for last Saturday.
Mike
Old Jul 13, 2006 | 04:54 PM
Brad S1's Avatar
UPS just showed up, rain or not I couldn't wait to mount my hella 500's
Old Jul 13, 2006 | 05:19 PM
Truck looks good with the lights. If you are wanting extra light at night you might consider replacing your headlight elements with the 80/100 watt bulbs from Hella, I think that was the brand I used. Anyway, factory bulbs are rated at 55/65 watt, I believe and boy what a difference they make. These are not the real brite white replacements, they burn at the same light range as regular bulbs but go alot further down the road.
They are about $12 a piece and you can buy them from Expedition Exchange on the web.
Mike
