General Disco RANT
Old Dec 21, 2016 | 07:58 AM
  #41
Fast951's Avatar
Well that's Land Rover ownership........just never forget the number>>>>
(Said in my best Larry the Cable Guy voice) I don't care who you are that's funny right there.
Land Rover - turning owners into mechanics for 70 years.
Old Dec 21, 2016 | 11:54 AM
  #42
jastutte's Avatar
I was telling my wife the other day I need to figure out a good British name to use when I want to whine about the Disco. In my E30 days, there were many times I used to cuss Jurgen for seemingly nitwit afterthoughts of design.
try "Jiles". it's about as British sounding as they come.
Old Dec 21, 2016 | 12:46 PM
  #43
OffroadFrance's Avatar
eerrrr, apart from the spelling eh, it's spelt Giles, with a G.
Old Dec 21, 2016 | 12:55 PM
  #44
IMHO, faced with the dilemma of the broken XYZ switch broken bolt, as The Deputy states, cur a hole in the transmission tunnel either square or using at least a 3" to 4" rotary tank cutter and drill out the bolt and re-tap the thread in the autobox casting and then fix a steel or alu plate over the hole and mastic it into place and drill and screw or pop rivet it. A relatively simple job to do but ensure to centre pop and centre drill the broken bolt first. The hardest part will be removing the carpet first but all up it's a couple of hours work, job done. Don't forget to re-direct and extend the A/C drain tube otherwise it will all be deja vue .
Old Dec 21, 2016 | 07:04 PM
  #45
Fast951's Avatar
Well, I got it. Cleaned away the corrosion near the break with a small wire brush and soaked with PB Blaster. Waited 24 hours. Hit it with my MAPP torch (small flame) for about a minute. Let cool and hit with PB again. Waited another day. Small Vice Grips on the nub and the POS time-wasting b@5tard broke loose.
Tomorrow I put everything back together with the new XYZ switch and move on. Hopefully.
Thanks for all the helpful comments and advice.
Old Dec 21, 2016 | 10:20 PM
  #46
Best4x4's Avatar
Victory!!!!
Old Dec 22, 2016 | 02:42 AM
  #47
The Deputy's Avatar
Darn it, does this mean we can't rant about our Discovery's engineering anymore...lol.
Nope, glad you got it out and can move on...now.
Good luck, with the rest of the repair.
Brian.
Old Dec 22, 2016 | 04:56 AM
  #48
Brian.
X1 ................... if at first you don't succeed ............. etc, etc
Good to hear you won the battle.
quote: Darn it, does this mean we can't rant about our Discovery's engineering anymore...lol. unquote: c'est la vie
Oh well, back to moaning about politics and politicians eh
Old Dec 22, 2016 | 05:07 AM
  #49
Nice one eh, at least you won . Just gotta get a new bolt now and a bundle of copper ease
But, you're not finished yet, don't forget to extend the A/C drain tube on the drivers side by about 6" and tie wrap it well out of the way. I believe it's about 8mm ID tube but check that size first. A/C condensate is pure(ish) water and very corrosive on steel.
Old Dec 22, 2016 | 07:36 AM
  #50
Fast951's Avatar
Originally Posted by OffroadFrance
....A/C condensate is pure(ish) water and very corrosive on steel.
Yes, very true. I saw a new Ford (prototype?) that recycles condensate into drinking water for passengers. Has a tap and storage bottle in the center console. Better than letting it drip into the vehicle's electronics, that's for sure.
