General Grabber Prices?
Old Feb 15, 2008 | 09:14 PM
WolfPack's Avatar
Default RE: General Grabber Prices?
Free shipping at Treadepot.com!
I coulda saved myself 50 bucks [:@]
Old Feb 16, 2008 | 11:45 AM
JPSAIA's Avatar
4th Gear
The Grabber AT2 is an awesome tire. Mine have performed well off-road, on road and in blizzard conditions of Colorado. Keep in mind that the majority of sizes for the Grabber are "P" and not "LT." The "P" are still great off road. You may have to adjust your size if your want "LT."
Hope that helps.
Jason
'97 Disco I
238,000 miles
Old Feb 16, 2008 | 05:37 PM
Camdisco24's Avatar
Yeah, they seem to get the best reviews, and have the best prices. I wasnt able to call around today but it looks like pretty much everywhere I call is going to be in the same general range. I dont know much about the "P" and "LT" stuff, i guess thats something else to look into!
THANKS FOR THE INPUT!
Old Feb 16, 2008 | 05:55 PM
ORIGINAL: Camdisco24
"P" is for passenger and "LT" is light truck.
The difference is the number of plys for the tires, "P" is usually 4 ply and "LT" is 6 or more. The more ply's you have the stronger the tire and the rougher the ride.
Make sure that the tires you get can handle the weight of the load they will be carrying.
More plys also allows for more air pressure, a "LT" tire might handle 100 psi where as a "P" tire could only handle 60 psi.
Not a consern for most people, but for farmers, delivery drivers and the like who load their trks to the max GVW you need to consider this stuff.
A "LT" tire with stiffer sidewalls will better handle being "aired down" for off road use and also hold up better to rocks and the like.
Your trk weight 6,000 lbs, so your tires need a 2,000 lbs rating min.
Old Feb 16, 2008 | 06:01 PM
Camdisco24's Avatar
Perfect, thanks. I think P will be fine for me, no big loads will be put on or pulled by this disco.
Old Feb 17, 2008 | 01:12 AM
WolfPack's Avatar
ORIGINAL: Spike555
It took me a long time to find that information . I was freaking out trying to figure out why a P265/75/15 was so much less expensive than a 31/10.50/15 (theyre the same size)! On the same tire!
Then I found it. I also learned most LT sizes won't give you a manufacturer's warranty, or a UTQG rating..
ragandhi
Nov 12, 2013 01:10 PM
cgap
Nov 20, 2011 08:20 PM
Tapper
Jun 1, 2011 05:48 AM
JerrodSteph
Nov 1, 2010 07:18 PM
Disco2Guy
Nov 25, 2007 09:54 PM
