Gentlemen : can we define overheating ?
Old Sep 1, 2015 | 10:54 AM
Externet's Avatar
Question Gentlemen : can we define overheating ?
What is your opinion to draw a line on a consensus coolant temperature ?
Many years ago, I read related to coolant temperature, that the correct working temperature of an ICE was taken as "so many degrees above ambient air temperature" Cannot remember the figure now; but could be an alternate way to express it.
Could it be 111C for our vehicles ?
Could it be 70C above ambient ?
Or, list your suggestions ?
Old Sep 1, 2015 | 11:15 AM
Alex_M's Avatar
For me 220 degrees, but anything over 205 is abnormal.
Old Sep 1, 2015 | 11:39 AM
Joemamma1954's Avatar
I agree, 205 is hot enough for my engine. I like to hover between 190-195.
Old Sep 1, 2015 | 12:15 PM
georgep's Avatar
Down the list using and UlTRA GAUGE for the OBDII conntecion (always in the dogs.
2001 P38 Ambient over 100 deg F Engine NORMAL 194 up to 205 at red light
1998 D1 Ambient over 100 deg f Engine Normal 194 up to 210 at red light.
2003 D2 Ambient at 94 deg f Engine Normal 201 (note needs bearing so higher temp seen)
Normal on P38 and D1 means A/C on and driving at up to 70 mph.
BOTH P-38 and D1 have ALL NEW cooling systems.
Before rebuilds:
P-38 251 to 265 with normal at 215.
D1 221 to 230 with normal at 210
I recommend to get an Ultra Gauge ($69.00) it saved the D1 engine and would have saved the P-38 if I had it.
No I do not work for them we have (4) in different cars.
Old Sep 1, 2015 | 12:33 PM
dgi 07's Avatar
Personally, 210 is my limit. That's when I start panicking....
Old Sep 1, 2015 | 12:53 PM
cappedup's Avatar
My UG alarm is set to 205. I expect this to happen past that.
Old Sep 1, 2015 | 01:33 PM
DiscoRover007's Avatar
Im suspicious of anything above 205 although that is not technically overheating. I think technical overheating is 230 F but I think consistently driving at 220 will cause gradual damage.
Luckily I don't have to ever see those temps again with the inline thermostat. I run 183-188.6 all day every day. If you haven't done this mod you should do it yesterday.
Old Sep 1, 2015 | 02:59 PM
Charlie_V's Avatar
230 is when the gauge moves.
I'm irritated at 212.
I panic at 220.
If I gets over 230 I just grab my phone and order a head gasket kit and call a tow truck.
Old Sep 1, 2015 | 03:02 PM
ATLDisco's Avatar
I average 194-197 driving on highway with AC on in Phoenix. Ambient is typically over 105, and can go to 119 on a bad day.
Hottest I've seen at stoplight is 208. I don't like to see anything over 205, but have only the low temp rover T-stat, and its the knockoff, not the OEM.
I also have the GP rover block with the ARP studs in it though, so I think it'll handle a little more than stock.
Last 4.0 engine I had with inline therm mod stayed around 186F all day every day.
Personally, if I see 205 I get attentive, anything over 210 and I'm shutting it down.
Old Sep 1, 2015 | 03:28 PM
OffroadFrance's Avatar
Originally Posted by cappedup
my ug alarm is set to 205. I expect this to happen past that.
excellent :d
