Getting fender flares off
Old Apr 27, 2018 | 11:47 AM
zuke's Avatar
Default Getting fender flares off
2 just popped off. 2 are being stubborn.
Heat gun?
Old Apr 27, 2018 | 12:09 PM
Best4x4's Avatar
Heat gun helps, but usually you’ll still end up with 3M tape residue on the LR. That 3M wheel really helps to get it off though!
Just gentle pressure usually will rip the adhesive in half or you could be lucky and get it all off.
Old Apr 27, 2018 | 12:17 PM
Jeff Blake's Avatar
Budget version of the 3m wheel that worked very well for me, and is a must for removing the residue
Amazon Amazon
Old Apr 27, 2018 | 01:22 PM
OverRover's Avatar
Heat gun?
If you don't care about possibly damaging the flares then a heat gun will work......BUT...
To remove the flares try the oldest trick in the book, fishing line.
First make 2 loops on the ends of the fishing line so you have somewhere to put your fingers (wear gloves this stuff will cut you)
for "leverage". Then get the line between the flare and body panel and slowly move it back and forth.
If it feels like there is too much resistance on the line, spray where the flare meets the body with some WD-40.
This method has always worked for me no matter what the vehicle.
For the adhesive it really depends on how much is left over. The 3M wheel always works great!
Acetone (like Goof-Off) will get it off and you won't need much. And even WD-40 will do the job. Just use a "bath" towel and not a shop rag/kitchen paper towel. The fibers in the towel will grab the old adhesive and not just push it around.
Good luck!
Old Apr 28, 2018 | 01:53 AM
Frank4's Avatar
I just ripped mine off. Used the 3M adhesive wheel to get the tape off. Took maybe 30 min total. No paint damage from ripping them off, most of the tape stuck to the fender.
Old Apr 28, 2018 | 06:24 AM
redwhitekat's Avatar
We're the fender flares just for looks or do they actually provide any protection etc. I seen a disco other day without them and I didn't mind the look
mb8780
Nov 15, 2012 07:12 PM
Kraftyz51
Aug 13, 2007 10:56 AM
mb8780
Mar 21, 2007 08:18 PM
joelxa513
Nov 10, 2006 12:33 PM
edthediscoman
Oct 28, 2005 05:10 PM
