Getting at flywheel...
Old Dec 1, 2008 | 05:55 PM
apcollin's Avatar
Default Getting at flywheel...
my truck is making a grinding noise once in a while when i start it; it seems like either the starter isn't engaging all the way or the flywheel is missing some teeth.
i don't want to replace the starter only to learn the flywheel is what needs replacment... my mechanic suggested i "remove the dust cover" to take a look at the flywheel, what is he referring to? is there something i can open up to take a look in there without dropping the transmission? it's a D1 Manual if that helps
Old Dec 1, 2008 | 06:18 PM
Default RE: Getting at flywheel...
On the bell housing, at the very bottom of it there is a inspection cover, remove this cover and take a look.
You need a new starter, the ONLY reason the flywheel will be missing teeth is because the bad starter chewed them off.
That is the ONLY reason you would need a new flywheel because of teeth missing.
Old Dec 1, 2008 | 06:32 PM
apcollin's Avatar
that's what i figured. i won't be able to get to the starter until around christmas time, but i only have to start the truck a few more times til then...
i first noticed the noise about a month ago but i don't drive my truck everyday... not even close to that often.
hopefully i won't do too much damage to the flywheel before i can replace the starter
Old Dec 2, 2008 | 09:38 AM
Christmas may be way to late for your flex plate. If your starter keeps grinding on the flex plate you will need to replace both at around $1400.
Get someone on it today or quit driving it till you can get the starter yanked out and replaced.
Old Dec 2, 2008 | 12:08 PM
apcollin's Avatar
i'm going with the latter, since i simply don't have the time right now.
like i said, i don't drive it as much as most people and i will only be starting it... three to five more times before i'm home and can deal with it.
fatman007
Nov 26, 2009 12:29 AM
halfmoontrail
Sep 22, 2009 02:20 PM
oliveoil
Oct 28, 2008 12:49 AM
ziploc99
Apr 19, 2008 12:39 PM
oliveoil
Jan 2, 2008 07:13 PM
