GIVE ME A BRAKE!
Old Feb 22, 2008 | 07:36 AM
EL GALLO's Avatar
Default GIVE ME A BRAKE!
HELLO GUYS.AS ALWAYS I TURN TO YOU FOR ADVICE AND KNOWLEDGE,THAT UP TO NOW HAS BEEN INVALUABLE.MY 2004 DISCO,20200 MILES,IS BRAKING ,WELL, VERY ROVER.I WOULD LIKE TO IMPROVE BRAKING SOMEWHAT AND HAVE CONSIDERED CHANGING PADS TO CERAMIC.I AM TOLD THEY ARE HARSHERONTHE ROTORS UNLESS THESE ARE MANUFACTURED IN A WAY TO WITHSTAND THE CERAMIC PADS.ANY ADVICE ON THIS MATTER OR ANY BRAKE ENHANCEMENTTIPIS FULLY APPRECIATED.THANK YOU.
Old Feb 22, 2008 | 08:03 AM
Darover's Avatar
Default RE: GIVE ME A BRAKE!
Changing your brake line for braided stainless steel helps quite a bit by augmenting the pressure at the brakes, instead of being absorbed somewhat by the rubber lines.
Old Feb 22, 2008 | 08:07 AM
The best solution is to switch to DBA, slotted and drilled rotors, not EBC's or any of the one's on E-Bay. Then use a good set of Kevlar brake pads and make sure to do a full brake flush using Vavoline's synthetic brake fluid that will handle the additional brake heat and make for a firmer brake pedal.
Old Feb 22, 2008 | 10:33 AM
ajh's Avatar
ajh
The brakes just suck, you can make them better with the above changes. If you go with larger wheels though you're just pretty much out of luck. Had a problem yesterday morning due to insufficient brake boost, very annoying any could end up being expensive.
I'm trying to get a hydroboost kit put together, it would be under $600 and should fix all the braking issues on the D2. I'm also looking at other options such as an electric vac boost pump to provide additional boost. The problem is just that there isn't enough pressure in the system for such a heavy vehicle, and once you increase wheel size, add accessories, and fill it with gear you're just way beyond what the stock vehicle is capable of.
amkullar
Aug 31, 2011 11:57 PM
alanski
Jun 13, 2008 11:16 AM
wileyabbas
May 23, 2008 02:50 PM
zracin
Feb 17, 2008 12:39 PM
KidGid
Jan 26, 2007 11:18 PM
