Glovebox alignment 2002
Old Feb 7, 2021 | 03:52 PM
Erik Griffiths's Avatar
Default Glovebox alignment 2002
Not my disco 2 but I have done a lot of work on one and the glovebox is killing me! Does anyone have a picture of stock mounting bolts\brackets so I can line this thing back up?? Was missing an entire bracket, we have it now, but it's still ever so slightly off and this taking off 4 bolts and guessing what needs aligned only to do it all again is killing me! Thanks! 2002 disco 2
Old Feb 14, 2021 | 11:10 PM
SurfinTillTheEnd's Avatar
I will take a picture tomorrow if you need but I had issues on my 03 disco. I figured it out by loosely putting the screws in the brackets then closing the glove box and tightening all the screws. Are you having issues closing the glove box? Also if I recall correctly the drive side has the same brackets if you wanted to see how it should look.
Old Feb 15, 2021 | 10:12 AM
Tony Luna's Avatar
OP - are you talking about the gap at the top of the glove box door when closed? Mine has a wider gap on the passenger door side than on the side that faces the middle/driver. Been trying to figure out how to even it out for a while.
cvhyatt
Jul 5, 2020 10:02 PM
xsxi005
Feb 14, 2014 12:33 AM
Bowesmobile
Audio/Visual Electronics
May 31, 2011 02:09 PM
WRDaley
Aug 28, 2010 10:06 PM
ASHR
Jun 27, 2006 03:31 AM
