GlowShift Oil Filter Sandwich Adapter and MANN 950/4
Old Aug 2, 2013 | 04:34 PM
caymandrew's Avatar
Default GlowShift Oil Filter Sandwich Adapter and MANN 950/4
Incase anyone is interested in knowing, the MANN 950/4 filters WILL fit on top of a GlowShift Oil Pressure Gauge Sandwich Adapter. I have an aired cooled system so no easy plugs to convert for use.
My Readings with Rotella 15w40 are:
Cold: 45 PSI at Idle 52 PSI 2000 RPM
Hot: 28 PSI at Idle 52 PSI 2000 RPM
Are these normal readings?
Obviously not done, wires just hanging for testing.
Old Aug 2, 2013 | 06:01 PM
caymandrew's Avatar
Old Aug 2, 2013 | 07:35 PM
ralphobell's Avatar
I would say your in good shape with those numbers.
Old Aug 2, 2013 | 10:34 PM
What about your engine noises after all the work?
Old Aug 3, 2013 | 08:01 AM
caymandrew's Avatar
The lower end knock is gone, it was the main bearings. In the process I did the rod bearings, timing chain, & oil pump. In searching some more I see these oil PSI number seem to be good for a disco 2.
Next I'm doing the camshaft, lifters, rocker arms and shafts. That should take care of the upper diesel sounding tick. Getting closer to a full rebuild.
Old Aug 3, 2013 | 10:50 AM
bosshogt's Avatar
What is the model number on the Glow shift adapter.
Old Aug 3, 2013 | 11:04 AM
re: That should take care of the upper diesel sounding tick.
It is common for a slipped cylinder sleeve to make a tick, usually starting when warmed up. Hope that is not the case, but others have pinned the liners and stopped the tick.
Old Aug 3, 2013 | 12:05 PM
caymandrew's Avatar
Oil filter sandwich adapter 3/4 unf 16
Understood. I did pin cylinder #1 while changing the main bearings as it was suspect. But the tick is right at cold start up. It's not bad, but I bought the truck as a project and planed to do as much of a rebuild as I can so it's all on the list anyway
Old Aug 4, 2013 | 12:18 AM
dr. mordo's Avatar
I read somewhere that some part of the suspension (maybe the axle itself?) would crush the filter with that extension.
You think it'll clear?
Old Aug 4, 2013 | 10:03 AM
caymandrew's Avatar
Been using this filter for months on and off road. No problems. It's tucked in right behind the frame and only protrudes down less than a half an inch. This picture says it all:
