GlowShift Oil Filter Sandwich Adapter and MANN 950/4
Incase anyone is interested in knowing, the MANN 950/4 filters WILL fit on top of a GlowShift Oil Pressure Gauge Sandwich Adapter. I have an aired cooled system so no easy plugs to convert for use.
My Readings with Rotella 15w40 are:
Cold: 45 PSI at Idle 52 PSI 2000 RPM
Hot: 28 PSI at Idle 52 PSI 2000 RPM
Are these normal readings?
Attachment 40182
Obviously not done, wires just hanging for testing.
Attachment 40182
I gotta call another post out for giving misleading information .. ..
This filter does NOT FIT. There is a bolt with lines in the way and it WILL NOT FIT YOUR DISCOVERY 2. He doesn't show it in his photo ... his lines are removed ....I forgot I had lines there until I went to install it. Now I have a new filter doing in the trash and forced to put the USED filter back on so I can drive it to Oreillys and get another filter and more oil and do it AGAIN because of this misleading info costing me time and money.
DONT LISTEN TO THIS GUY, THE FILTER DOES NOT FIT.
If you have an oil cooler it might not, but it would fit my 04 without issue. I never saw the point in huge oil filters just do regular changes, and use a good quality filter and oil.
