Is it a good idea to preventatively replace my radiator?
Old Oct 23, 2019 | 09:01 PM
Brandon318's Avatar
Default Is it a good idea to preventatively replace my radiator?
Just added a 2004 Disco to the fleet with 78,000 miles on it. Dexcool for days. I replaced the radiator on my 2002 Disco with 154,000, sawed the radiator in half and saw so many of the coolant galleries plugged up. Should I replace the radiator on the 2004 assuming it too is plugged up, or skip this interval and maybe consider replacing it at something like 100,000 miles?
In the BMW world, radiators on old E36s were replaced at 75,000 miles, no question, just do it. I haven't gleaned that there's a recommended replacement interval for D2 radiators.
Old Oct 23, 2019 | 11:49 PM
FlyingZebra34's Avatar
I haven't replaced one if it wasn't leaking. But I also have one of those silly laser heat guns to check for cold or hot spots to alleviate my stress.
Old Oct 24, 2019 | 02:41 AM
JUKE179r's Avatar
I carefully monitor my engine temps on my iPad with the UltraGauge Blue adapter so I'll wait on replacing my original radiator.
Old Oct 24, 2019 | 04:17 AM
shanechevelle's Avatar
Flush it with super flush.
Old Oct 24, 2019 | 07:21 AM
jastutte's Avatar
hell, as cheap as the radiators are, if you have the time change it out.
it'll be peace of mind and one less thing to worry about.
Old Oct 24, 2019 | 07:33 AM
Sandman614's Avatar
May as well grab some of @abran fancy new Aluminum coolant parts if you are going after preventative cooling system maintenance.
Old Oct 24, 2019 | 08:07 AM
wjsj69's Avatar
If I had the $ and time, I'd replace everything that could possibly fail, all at once. Since that's not feasible, I just fix what needs it as necessary; hopefully before complete failure. Most things give warnings before then if you're paying attention-and you should be with an older vehicle. If it's a point of stress/worry for u, replace it.
Old Oct 24, 2019 | 08:13 AM
WaltNYC's Avatar
Replace it. And find a couple of other things to freshen up while you have easy access. Trans cooler lines and what not.
Old Oct 24, 2019 | 08:54 AM
abran's Avatar
@Sandman I think we need to work out a commission schedule for you!
thank you for your support!
Old Oct 24, 2019 | 10:03 PM
Discorama's Avatar
If you are at it, add the OEM oil coiler.
