Got It!!!!
Old Aug 10, 2007 | 08:12 AM
chargersfan's Avatar
Default Got It!!!!
Well I got it, traded my 91 Jeep for it. I got the better deal on this one. There are just a couple issues that I would like to run by you guys.
1. To start you have push down on the accelarator, sounds like it is starving for fuel at startup, then it runs great.
2. Rear windows won't roll up, I think this is due to the regulators.
3. Power mirrors will not work, is there a common issue?
That's it pretty minor. I'm excited this thing is sweet. Big step up from the Jeep
Thanks Brian
96' Disco 148,000
Old Aug 10, 2007 | 08:21 AM
Default RE: Got It!!!!
The starting isues should be resolved, if you want a list of stuff to check out, get back to me.
As for the windows and mirrors, you may have a bad body ECU causing this to happen.
Mike
Old Aug 10, 2007 | 08:27 AM
okdiscoguy's Avatar
Not sure how mechanical you are....
There is a silver tube running around the top of the engine (fuel rail) On the passenger side there is a valve that looks like a regular tire valve. Take off the cap and check to see if there is pressure with just the key on. When you first turn the key, you should hear the pump priming up.
Pull the switches and clean them with plastic safe electrical cleaner. Mine was the same way when I got it and the switched were all gunked up from spilled drinks.
Not sure on the power mirrors, just have to trace out the circuit.
Go to rover-renovations.com . Search for the Rave CD. They will send you one for free. It has all of the manuals and electrical books you should need.
Good Luck and welcome to the group!
Old Aug 10, 2007 | 08:35 AM
Wow you guys are fast thanks for the help, I will check that fuel rail
Old Aug 10, 2007 | 08:38 AM
Landzu's Avatar
Change the fuel filter.
Right rear wheel well on the frame.
glassman66
Jul 7, 2012 03:10 PM
Analogkid
Oct 28, 2010 05:38 PM
lipadj46
Sep 12, 2009 07:31 AM
Disco2Fever
Oct 19, 2008 08:05 PM
jiminoc
Jan 26, 2005 04:05 AM
