Got a temperature gun -- Measured the cooling system
Old Mar 20, 2018 | 03:49 PM
Saturnine's Avatar
Hmmm.. had an UG before I had MagPie, it’s always plugged in and set on engine temp.
Old Mar 20, 2018 | 03:52 PM
Best4x4's Avatar
Anything past 235F with these engines and she’d be dying. I’d certainly try a new sensor because 260F sounds bonkers.
Old Mar 20, 2018 | 03:54 PM
Saturnine's Avatar
Hmmm.. ok. Where is said lower temp sensor? On the Rad?
Friday Night Disco's Avatar
What if the air pocket is next to the sensor?
Based off the comment of going up hill the temp spiked would leave me to believe the air pocket moved to where the sensor is located and not the sensor itself
Old Mar 20, 2018 | 04:11 PM
Best4x4's Avatar
Yeah it could be in the area of the sensor for sure (I’ve dealt with plenty), but highest I ever got was 229F to 235F tops with an air pocket. 260F just sounds a bit high to me.
Does the heater have a good heat output? I could certainly see a pocket of air stuck in that area with a blocked heater core. The air bubble really wouldn’t have anywhere to go.
If the heater core isn’t clogged with good heat the air pocket should make it’s way to the T eventually after several hot/cold cool down cycles.
Old Mar 20, 2018 | 05:06 PM
Saturnine's Avatar
Just drove to school with no problems.. Heat was off and on so gotta still be a bubble someplace. When the heat is hot it’s HOT which is nice.
Arg.
Old Mar 20, 2018 | 05:42 PM
Best4x4's Avatar
Gotcha
Old Mar 20, 2018 | 06:02 PM
number9's Avatar
Originally Posted by Saturnine
Isn't it fairly rare that a temp sensor would be poo?
Rare but they can be faulty
You can get a very good idea of sensor accuracy by taking a IR reading right there at the manifold where sensor is mounted. My sensor/ScanGauge was about 5 degrees warmer than the IR indicated.
The lower sensor should not cause an erroneous temp reading. It's role is to monitor temp differences no to indicate ETC. '01 probably doesn't have the lower sensor but if it does no harm in changing if it makes you feel better.
The thermostat monitoring sensor is located in the radiator, adjacent the bottom hose. The ECM compares the
temperature measured by the thermostat monitoring sensor to the temperature measured by the ECT sensor. If the
difference between the two readings is too great, the ECM determines the thermostat is stuck. In this case, the ECM
registers a fault code in its memory.
Old Mar 20, 2018 | 06:37 PM
Best4x4's Avatar
On a few SAI equipped D2’s I worked the system set faults and was basically acting like the old days with Prince of Darkness electronics. New Bosch sensor on the SAI’s extra temp sensor and no more stupid P0126 or irrelevant fault codes.
I had an 02 that was a nightmare with codes that wouldn’t pass state inspection and SAI was my nightmare. All other SAI trucks I’ve had zero issues.
SAI was around from 99-04. On earlier models it had to be a low emissions CA sold vehicle. 03-04 = it was pretty much standard equipment although some 03’s have passed thru my hands without SAI and were imported into TX or LA.
Old Mar 20, 2018 | 10:12 PM
number9's Avatar
Sometimes this forum really gives me chuckle.
