Got the valve covers off, what do you think?
Old Jun 8, 2013 | 04:31 PM
caymandrew's Avatar
Default Got the valve covers off, what do you think?
Replacing the coil packs and throttle body heater today so I decided to just do the valve cover gaskets and have a look while I'm in there. The right side seems a little dirtier than the left? What can be used to safely clean the springs and rocker arms or just don't worry and let rotella do it?
Old Jun 8, 2013 | 07:43 PM
Shade Tree's Avatar
Looks cleaner already than mine was after pressure washing, soaking and scrubbing.
A wise man told me once a long time ago, "Boy, don't fit it if ain't broke."
Old Jun 8, 2013 | 07:50 PM
bosshogt's Avatar
Carb cleaner will clean the oil off the arms, but it really does not matter. its on the outside of the rocker arms. No real benefit to the engine... other than to look good. Someday when you drop the oil pan to replace your oil pan gasket, you will see all the brown coating. Its fine. Just run Rotella and all will be good.
Old Jun 8, 2013 | 07:55 PM
Dirty? This is dirty....
And after working on it I wonder if I will ever stop smelling like Rotella, SWMBO said she was going to spray me with Lysol...
With four bolts you can have those rockers off as an assembly, mine feel gritty when operated, so I will soak them.
Be sure all your PCV components and passages are clear.
Attached Thumbnails Got the valve covers off, what do you think?-p1050954.jpg   Got the valve covers off, what do you think?-p1050979.jpg
Old Jun 8, 2013 | 08:22 PM
caymandrew's Avatar
Thanks for the pic Buzz. With 153k miles this truck it just continues to amaze me how well kept it must have been. Wow I feel bad for the guy who thought he was getting one over on me, by selling it for $3500 with an undisclosed oil leak.. That was fixed with a $12 bottle of white sheppards rear main
Old Jun 8, 2013 | 08:25 PM
While it is apart, consider reading my sticky at the top of this section on valve train noise then do their step by step inspection cause you will most likely have some wear at your mileage.
Old Jun 8, 2013 | 10:00 PM
Jmreed81's Avatar
Default Rebuilt heads?
It is common to remove the rocker arm assembly before hot tanking heads. Your heads appear to have been tanked at some period, probably when the head gaskets were replaced...lol? Do you know if it has been built in the past. That would explain the clean heads and discoloration on the rocker arm assembly. Never seen a engine with 153k miles that looked that clean. Even without sludge buildup, a amber hue is common, yours look like new aluminum. Nice engine!
Old Jun 9, 2013 | 12:32 AM
caymandrew's Avatar
You are correct, the head gaskets were done just before I bought it about 10k miles ago. I figured while it was all apart no sense in leaving all the other parts to look their age when the heads are so damn purty:
Old Jun 9, 2013 | 07:16 AM
Also, make sure you poor oil all over the valve train before you put it back together so you won't damage the rocker shafts, rockers lifters and cam.
By the way did you read and do what I suggested regarding the valve train. if so, what did you find?
Old Jun 9, 2013 | 09:34 AM
caymandrew's Avatar
Hi Mike, I did check out the link which went right to "Setting Tappet pre-load step by step ". Not going into the valley gasket I figured that wasn't for me. Of course now that I have everything back together I re-read the entire page and saw the section for "Identifing worn Rockers" which is what I now think you were trying to alert me too! It'll have to wait till next time.
