Got a Water Leak on my passenger side floor?
Old Jul 21, 2015 | 06:17 PM
MPDano's Avatar
Default Got a Water Leak on my passenger side floor?
I noticed my car smelled very muggy about a week ago and saw this this morning. I got water all over the floor passenger side. I am ruling out heater core as it's water and not coolant. What I have noticed is that I run my AC all the time and never see a water puddle under my car. Is something clogged somewhere?
Attached Thumbnails Got a Water Leak on my passenger side floor?-20150721_155656.jpg   Got a Water Leak on my passenger side floor?-20150721_155833.jpg
Old Jul 21, 2015 | 06:29 PM
It's either your AC drains or sun roof drains. AC drains usually leak down the trans tunnel hump.
Old Jul 21, 2015 | 07:05 PM
wyrdvans's Avatar
If the plastic windshield cowl is warped, water can get in through the heater air intake located under the cowl on the passenger side.
Old Jul 21, 2015 | 07:21 PM
drowssap's Avatar
X2 on the ac drains
Old Jul 21, 2015 | 08:24 PM
Joemamma1954's Avatar
mine looked just like that and both a/c drains were clogged. carpet has been dry for 2 months now.
Old Jul 21, 2015 | 08:37 PM
drowssap's Avatar
Usually you will get a musty odor insteed of that sweet coolant odor.
Old Jul 21, 2015 | 09:14 PM
MPDano's Avatar
Thanks guys. Used this link to point me in the right direction.
https://landroverforums.com/forum/di...se-help-52320/
Both AC Drains clogged. I took pics of location as well as gunk before and after cleaning. They are both on the trans tunnel pretty much next to the trans filter cover.
Used a metal hanger to initially poke it and a stream of water came out. Used my wet/dry vacuum to pull most of the water off the carpet, front and rear.
Attached Thumbnails Got a Water Leak on my passenger side floor?-20150721_183150.jpg   Got a Water Leak on my passenger side floor?-20150721_183251.jpg   Got a Water Leak on my passenger side floor?-20150721_183734.jpg   Got a Water Leak on my passenger side floor?-20150721_183901.jpg   Got a Water Leak on my passenger side floor?-20150721_182551.jpg
Old Jul 21, 2015 | 10:24 PM
cybercop's Avatar
I really don't understand what I am looking at in the 3rd and 4th pictures.
Old Jul 22, 2015 | 07:42 AM
MPDano's Avatar
Those are what are located at the end of the drip tube. I removed one to clean it out. The other one is above the cat and if I remove it, I wont be able to put it back on. I used the hanger and finger to clean it out while still on the drip tube.
Old Feb 6, 2023 | 04:45 PM
mackendw's Avatar
get a pair of long handle pliers...you can push it in the round tube...tight fit bit it works.
JEFIII
Feb 5, 2023 08:31 AM
PackAttack12
Sep 14, 2019 11:52 AM
MichaelDisc02
Jul 27, 2015 12:10 PM
dougn
Dec 4, 2012 06:25 PM
Princess
Sep 15, 2009 08:02 PM
