Greasable U-Joints
Old Jun 9, 2008 | 06:15 PM
discobob's Avatar
Default Greasable U-Joints
Been reading about the importance of replacing the front u-joint with the greasable variety. Where can I purchase them and approximately how much can I expect to spend on the parts? Thanks in advance.
Old Jun 9, 2008 | 06:20 PM
Goose_Cat's Avatar
Default RE: Greasable U-Joints
NAPA has 3 for under sixty dollars
Old Jun 9, 2008 | 06:37 PM
discobob's Avatar
Ooops. 2000 Disco II. 105,000 miles. I always forget to say that.
Old Jun 9, 2008 | 08:40 PM
PalmettoDisco's Avatar
Don't forget to get the centering pivot bearing & ball that's in the middle of the double cardon joint (in between two of the u-joints at one end of the front driveshaft). It's about 26 dollars. The old one is pressed in (a bit of a pain to remove), once out, press in the new one.
Edit: Adding some info from a previous post I made, and more.
The "ball kit" part # is either
Neapco 7-0081NG
or
Precision 617
Either brand works.
For U-joints:
Note: the Neapco U-Joint is nice (part # 1-0005), it has the grease zerk nipple in the end cap, making for easy greasing. The Precision 344 u-joints do not have the endcap zerk fitting, but is in the base of the joint (less friendly to grease). If your parts supplier looks up the u-joint by vehicle make and can't find a LR Disco, get a u-joint for a 1993 Volvo 240 (same joint size).
If you do this yourself, be extra careful not to dislodge any of the needle bearings in any of the afore mentioned parts.
JCJarhead
Mar 5, 2011 05:21 PM
JBEGIN
Dec 6, 2008 01:14 PM
IMurray21
Nov 13, 2008 09:54 PM
Phototone
Apr 24, 2008 05:15 PM
bigugly82
Oct 9, 2007 03:58 PM
