Grease joints
Stock you should have four. Front and rear prop shaft slip joints, rear prop shaft U-joint at the TC end and front prop shaft U-joint at the diff end. If you have a rebuilt front shaft you will have six with both U-joints in the double cardan now included, and maybe a seventh if the centering ball in the DC is greasable.
Love U Landie
02-04-2013 03:17 PM
