Grease joints
Old Nov 23, 2012 | 12:29 PM
redwhitekat's Avatar
Default Grease joints
How many grease joints are on the 04 discovery ??
Old Nov 23, 2012 | 07:44 PM
mossmanxjt's Avatar
Stock you should have four. Front and rear prop shaft slip joints, rear prop shaft U-joint at the TC end and front prop shaft U-joint at the diff end. If you have a rebuilt front shaft you will have six with both U-joints in the double cardan now included, and maybe a seventh if the centering ball in the DC is greasable.
Old Nov 23, 2012 | 08:08 PM
lr2001silver's Avatar
Banned
I think he is referring to the whole truck not the drive shaft.
Old Nov 23, 2012 | 11:05 PM
mossmanxjt's Avatar
I've looked around pretty well, on an '04 the only serviceable grease joints I could find we're the ones on the driveline.
Old Nov 24, 2012 | 12:16 AM
nahtanoj's Avatar
same on my '03. looked at everything and only have greasable drive shaft joints.
Old Nov 24, 2012 | 07:48 AM
Thanks I'm going to start doing my own oil changes but don't have a lift so kinda hard to see under there. I do have a tw pro shaft I think it has 3 fittings on it
Old Nov 24, 2012 | 09:23 AM
antichrist's Avatar
The TW proshaft will have 5. One on each u-joint (3), one on the center head, one on the slip joint.
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
Spencerfitch
May 14, 2010 06:28 AM
lipadj46
Oct 3, 2009 11:01 AM
Darover
Apr 2, 2008 08:06 PM
