grease nipples
Old Dec 6, 2007 | 07:12 PM
willstevens's Avatar
Default grease nipples
driveshafts , u joints ...
is there a complete list and location for all the grease fittings?
Old Dec 6, 2007 | 08:18 PM
Default RE: grease nipples
You have, or should have 4 grease fittings on the front drive shaft, one of the front u-joint, should have 2 on the back side of the front drive shaft where it attaches to the t/case and on on the slip joint where there is currently an allen plug. On the rear shaft you have one grease fitting on the u-joint and should add one to the slip joint where there is now an allen plug.
Old Dec 7, 2007 | 04:56 AM
so just the shafts and u joints, no other joints or axles or anything? That should be pretty easy to manage.
Old Dec 7, 2007 | 10:25 AM
At your mileage, I would suggest you crawl under your truck, and inspect the roto flex that attaches the rear drive shaft to the rear diff, looking for cracks in the rubber between the bolts.
Old Dec 7, 2007 | 01:37 PM
The roto flex is on order. I will handle that project myself. So no other grease fittings that I need to know about?
Old Dec 7, 2007 | 01:39 PM
No, but who are you going to have do the rebuild on the double cardon?
Old Dec 7, 2007 | 01:49 PM
Cincinnati Driveline did it yesterday.
Old Dec 7, 2007 | 02:53 PM
OH good.
Old Dec 7, 2007 | 04:13 PM
grease-able naepco joints and cv ball kit. I listed the part numbers in another thread. Parts and labor was $216.00. balanced and out the door. thanks for the help. I am on my way out here shortly to pick up the Disco from the shop that did the gasket work. mostly preventative maintenance stuff but it started with the search for the coolant leak.
angunique
May 4, 2014 05:26 PM
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
Paul Grant
Mar 30, 2012 10:29 AM
Phototone
Apr 24, 2008 05:15 PM
