Grease on the rear hub?
I don't think you'll find it's grease Dusty, it's more than likely axle/diff oil and your rear seal O ring is letting by oil. How to replace the rear axle seal - Land Rover Forums : Land Rover and Range Rover Forum
If you look in RAVE section/page 51-3 you will see the section through the rear hub which shows the offending O ring.
Mine has exactly the same problem and needs fixing. Awful job means draining the diff, stripping off the brake caliper, carrier, hub etc and fitting a new O ring.
Axle seals are right next to the hubs. When they leak oil, they'll pick up some dust and dirt and will look like grease. I just did this job. its a pita.
The hubs (if your going to stuff grease into them) looks like they are sporting white lithium grease. I could be wrong though. When I looked at my hubs last they had a light blue-ish tint to them.
![Smile](https://landroverforums.com/forum/images/smilies/H5uKDcM.png)
Love U Landie
02-04-2013 03:17 PM
