Grease on the rear hub?
Old May 9, 2014 | 04:07 PM
chicane's Avatar
Question Grease on the rear hub?
I took off the rear drivers side wheel to do some brake work. I removed the caliper and noticed there was a good bit of what appeared to be caked on grease all around the hub area.
Is this grease from the hub and do I need to re-pack it?
Old May 9, 2014 | 04:43 PM
ls1morethanyou's Avatar
They are not serviceable, but if you remove the sensor you can re pack it with grease. I did that and it worked but my hub is just worn out enough towards where the sensor doesn't always pick it up.
Old May 9, 2014 | 06:22 PM
dusty1's Avatar
That grease maybe dried up goopy oil from your diff. Axle seal maybe on its way out
Old May 9, 2014 | 06:44 PM
OffroadFrance's Avatar
I don't think you'll find it's grease Dusty, it's more than likely axle/diff oil and your rear seal O ring is letting by oil. How to replace the rear axle seal - Land Rover Forums : Land Rover and Range Rover Forum
If you look in RAVE section/page 51-3 you will see the section through the rear hub which shows the offending O ring.
Mine has exactly the same problem and needs fixing. Awful job means draining the diff, stripping off the brake caliper, carrier, hub etc and fitting a new O ring.
Old May 9, 2014 | 08:32 PM
Dane!'s Avatar
Axle seals are right next to the hubs. When they leak oil, they'll pick up some dust and dirt and will look like grease. I just did this job. its a pita.
The hubs (if your going to stuff grease into them) looks like they are sporting white lithium grease. I could be wrong though. When I looked at my hubs last they had a light blue-ish tint to them.
Old May 9, 2014 | 10:27 PM
dusty1's Avatar
^ the manufacturers have not been consistent with the lube. I have one with a very light (lith. looking)....1 with regular grease and 2 that appear to have gear oil....
still say its the axle seal (spring broke or just worn out) cheap and easy!
Old May 9, 2014 | 10:34 PM
dusty1's Avatar
easy job. get a 1 1/4" socket (it fits better on the stake) and, by the way, that is exactly what I am saying, oil (diff oil) looks like grease with the brake and road grime.
Old May 9, 2014 | 11:36 PM
there is a short video of me removing the rear hub. pretty easy when you have the tools/ help.
Old May 10, 2014 | 02:32 PM
Sorry Dusty.................brain fade on my part.............ma age ya know ..............you said diff oil originally .
MarkSF
Mar 4, 2014 11:31 AM
Love U Landie
Feb 4, 2013 03:17 PM
oljohnboy
Apr 11, 2011 08:40 PM
LeakyDisco
Sep 19, 2010 03:02 PM
01 Discovery
Dec 1, 2006 12:07 AM
