greasing front drive shaft
Any grease is better than no grease.
Ask 20 people and you'll get 20 different brands of grease.
I off-road a lot so I use Castrol Pyroplex Blue. It's made for heavy trucks used especially in harsh environments and is formulated to get tackier when it gets wet, rather than fall apart like some grease does.
Yes there should be three grease fittings on the double cardon joint.
Just go to AutoZone and buy a grease gun and Valvoline grease.
I use Green Stuff, it is made for farm equipment, same as AntiChrist, heavy duty applications and great for high dust and lots of water.
Grease the u-joints at every oil change.
On a DII the rear driveshaft does not have grease fittings.
on
As for grease, any of the better synthetic greases will work well, grease them twice a year and don't forget to do both slip shafts also.
I use the http://www.greengrease.net/.
Its great if you live in winter months with the salted roads.
