greasing front shaft centering ball
Old Jun 4, 2010 | 09:40 PM
Wolkesan's Avatar
antichrist is spot on. No real reason for you to pull the shaft other than to check the joints for binding. The original drive shaft has no means of allowing you to grease the centering ball. It sounds like you have been been doing it right.
Old Jun 4, 2010 | 10:01 PM
lordmorpheus's Avatar
Given my last experience with greasing everything, I think I could pull the shaft, grease all 3 joints and the slip yoke, and reinstall it in less time than trying to move the vehicle forward and backward in attempts to make the zerks accessible.
Side note: Last time (this past weekend) I did note that the joint on the rear driveshaft didn't seem to want to take grease at all. Looks like I'm going to have to engage CDL and have a FWD Disco for a day while changing it.
Old Jun 4, 2010 | 10:02 PM
rj95lss's Avatar
Originally Posted by lipadj46
The best way to grease the centering ball is to remove the entire drivehshaft.
I think its quicker and easier to just remove the side to the t-case on my TW shaft - just saying....
I also did a write with step by step pictures on how to do this in 30min or less in and out of the garage.
Old Jun 4, 2010 | 10:51 PM
jtherien53's Avatar
CENTERING BALL!!!...i have spent this last day messing with this centering ball..flathead, slide hammers, small prybars. does anyone have another way of removing this easily (or easier i should say). any advice will help
Old Jun 5, 2010 | 01:40 PM
JavaDiscoII's Avatar
Originally Posted by lordmorpheus
"I grease the three front and one rear U-joint every oil change" and also the slip shaft. (Just wanted to add that before someone jumped me for forgetting something)
Pardon my ignorance, but what is a slip shaft. That keyword doesn't appear anywhere in my RAVE
Old Jun 5, 2010 | 03:16 PM
On the front driveshaft, there is an allen-headed screw on the shaft itself that oyou remove, install grease zerk, and lubricate the inside of the shaft itself. When finished, remove zerk and reinstall allen head set screw. The front shaft is actually two pieces, not counting the yokes, double cardan, etc. The shaft can change lengths as the front axle moves. This zerk allows you to keep the shaft lubricated, to allow for ease of extension and contraction.
Old Jun 6, 2010 | 07:16 AM
antichrist's Avatar
This last time, I spent 20 minutes pulling forward, checking, backing up, checking, over and over until the zerks were facing down. (couldn't put it in neutral due to sloped driveway, and don't trust chocks)
If you don't have access to good wheel chocks, just get a piece of 4x6 from your local lumber yard and use that.
Jack up one front wheel and put the axle on a jack stand, then put the transfer case or gearbox in neutral.
Old Jun 6, 2010 | 07:28 AM
antichrist's Avatar
A picture is worth a thousand words
richief556
Jul 31, 2013 03:28 PM
barsa
Dec 14, 2010 08:07 PM
phil29
Oct 7, 2010 10:26 AM
jw928
Feb 28, 2009 10:26 PM
Night Train
Nov 28, 2008 11:17 AM
