Great Price on a Window Regulator But ...
I had a regulator get funky on my D2 soon after I bought it. It made a nasty sound when I closed the window so I pulled the door panel and lowered the window to check the rollers and in the process folded up one of the arms which had a broken roller. I straightened it out enough to get the window up and ordered a new one from a west coast Rover supplier. It was only $35! I installed it after it arrived and when I put the window up, it made a clunking noise at the limit. I lived with it for a while then the glass started to drop about 1/4" after it was closed, then it stopped closing al together. I pulled it out over the weekend and found a bunch of the teeth had sheared off. The gear on the regulator must have been welded on out of alignment causing the teeth to only partially engage. Nice. I had saved the old regulator so I was able to swap over one of the rollers after pounding the bent arm back into shape.
Wonder if anybody else has seen this.
Al Blue4.6l
Aug 14, 2011 05:28 PM
phillman98
Dec 4, 2010 10:01 PM
