green S light on dashboard?
i went to US yesterday, lined up for 1 hour finally get through the border, but there is a green S warning light came up.
we checked owner's manual, it says it is indicating Sports Mode, we are not sure why it came out, and how to get rid of it.
please help!
please help!
ORIGINAL: mimimi
please help!
please help!
Just curious but how do you even get through life?
ORIGINAL: NWDiscoRover2004
higher performance. makes the land rover feel and act spunkier. carefule though, it consumes gas at a greater rate.
ORIGINAL: mimimi
thanks for all your reply.
we are just new owner to this car, have not had time to play with all the buttons yet.
this is an indicator that you are in "sport" mode. while in this mode, your trans will kick into passing gear easier and the engine will rap out to a higher rpm before shifting.
If you are in Low Range and push the Mode button and you will or should see a light on the dash similar to before, only there will be an "M" in the middle. This is an indicator that you are in "manual" mode.
When in this mode your trans will stay in whatever gear you select. I.E. 1,2,3,D etc.
dk
johnkbl
Jan 13, 2009 08:54 PM
