green S light on dashboard?
Old Nov 12, 2007 | 03:40 PM
mimimi's Avatar
Default green S light on dashboard?
i went to US yesterday, lined up for 1 hour finally get through the border, but there is a green S warning light came up.
we checked owner's manual, it says it is indicating Sports Mode, we are not sure why it came out, and how to get rid of it.
please help!
Old Nov 12, 2007 | 03:46 PM
Camdisco24's Avatar
Default RE: green S light on dashboard?
Press the "MODE" button on the PRNDL that will turn it off.
Old Nov 12, 2007 | 05:39 PM
mimimi's Avatar
i will try that right away, thanks for your reply.
by the way, what is different for Sports Mode?
Old Nov 12, 2007 | 06:20 PM
Darover's Avatar
lets the r.p.m go higher before changing gears.
Old Nov 12, 2007 | 06:50 PM
NWDiscoRover2004's Avatar
higher performance. makes the land rover feel and act spunkier. carefule though, it consumes gas at a greater rate.
Old Nov 12, 2007 | 08:04 PM
Camdisco24's Avatar
Its only good if your late for work.
Old Nov 13, 2007 | 08:21 AM
S4poor's Avatar
ORIGINAL: mimimi
please help!
The "S" stands for "Stupid, RTFM".
Just curious but how do you even get through life?
Old Nov 13, 2007 | 11:37 AM
mimimi's Avatar
thanks for all your reply.
we are just new owner to this car, have not had time to play with all the buttons yet.
Old Nov 13, 2007 | 11:39 AM
mimimi's Avatar
ORIGINAL: NWDiscoRover2004
thanks, we filled up a whole tank of US gas, 30-40% cheaper than Canadian gas
Old Nov 13, 2007 | 12:44 PM
dkeach's Avatar
ORIGINAL: mimimi
In high range.. push the "mode" button. the light on the dash is a picture of a gear with an "s" in the middle.
this is an indicator that you are in "sport" mode. while in this mode, your trans will kick into passing gear easier and the engine will rap out to a higher rpm before shifting.
If you are in Low Range and push the Mode button and you will or should see a light on the dash similar to before, only there will be an "M" in the middle. This is an indicator that you are in "manual" mode.
When in this mode your trans will stay in whatever gear you select. I.E. 1,2,3,D etc.
dk
Disco Den
Dec 4, 2010 09:42 PM
marlin883ss
Jun 22, 2009 10:46 AM
icoolyou
Dec 17, 2007 02:33 PM
Durfee
May 9, 2006 03:04 AM
