Grill
Old Jun 3, 2011 | 08:38 PM
rhudy's Avatar
Default Grill
trying to remove grill on 2002Disco, can get the 3 screws ontop no problem but it will not come out? any ideas
Old Jun 3, 2011 | 09:02 PM
I removed one in the salvage yard by taking off the three screws you found, plus removing both front turn signal lamps, which revealed a single screw on each side that holds a piece of trim in place on each side of the bottom of the grille. I got mine from a green Disco, and it went back on my black one, had to rattle can spray the bottom rail to match color. I believe the lenses come out with some sort of spring connector that you can see if looking straight down with the hood open.
Alex_M
Feb 11, 2015 09:06 AM
DeluxeRN
Jul 31, 2011 10:06 PM
STi NUt
Appearance & Camping Set Ups
Mar 12, 2006 03:15 AM
thesaintnr1
Feb 7, 2006 08:16 PM
thunderchicken
May 10, 2005 01:23 AM
