Grinding Sound on startup and idle
Old Oct 12, 2021 | 04:13 PM
adalton's Avatar
Default Grinding Sound on startup and idle
Hi guys,
My disco has been doing this since I got it over a year ago but its starting to bother me. Whenever I start my truck there is this grinding sound when the idles drop to around 660 rpm. Its been starting to happen when I shift into drive or reverse as well. It is coming from what seems to be the drivers side of the engine bay. It doesnt happen when driving or when it is above the idle rpm. If anyone could help me out that would be great.
Old Oct 12, 2021 | 06:18 PM
tnrangerover's Avatar
Originally Posted by adalton
Hi guys,
we can’t help you without some sort of video. It could be many different things.
Old Oct 13, 2021 | 02:32 AM
The Deputy's Avatar
How long does it make noise, if you don't move vehicle? Does it ever go away, like if you've driven ten miles and then idle it again, does noise return? Have you checked trans fluid (must be done with engine running)? Checked power steering fluid? Maybe remove fan belt and see if this changes anything. Does your engine have SAI, could be bad pump, it comes on for a few minutes on start up.
Old Oct 13, 2021 | 06:54 AM
adalton's Avatar
I have a feeling it might be transmission related. Ive been starting to notice a rough 1st to 2nd shift the past few days. I will check fluid and change if necessary.
Old Oct 13, 2021 | 03:56 PM
The Deputy's Avatar
Check your transfer case fluid level also, highly overlooked and usually leak. So, while you're under there...give it a look.
Old Oct 14, 2021 | 07:20 AM
adalton's Avatar
So I used a stethoscope underneath the truck and the sound seems to be coming from my muffler area or exhaust pipe. Do you think it could be caused by something loose inside the system?
Old Oct 14, 2021 | 01:19 PM
Harvlr's Avatar
Muffler baffles can come loose and rattle.
middlemontana
May 25, 2021 07:21 AM
Jason NCC
Defender
May 12, 2021 10:00 AM
bmoc81293
Discovery Sport
Feb 2, 2021 04:15 PM
jacumja
Apr 9, 2011 03:45 AM
snowdude
Sep 12, 2008 11:05 PM
