Ground Point 96 disco please help!!!
Old Jan 3, 2006 | 01:36 PM
grrRover's Avatar
Default Ground Point 96 disco please help!!!
I have a 96 disco with 183k on it and latlly had had a lot of electrical gremlins. First my stater went then a few weeks later it seemed like my battery replaced that then it seemed like my alternator so I replaced that. Well a new battery starter and atl later I am still haveing a problem with the battery charging not to mention the dash lights acting wierd. The disco runs fine once cranked but doent seem like it is chargeing the battery. and cooling very well. I am replacing the idler pully tonight and hops this help but i am wondering if a I have a bad ground somwhere and thats what is causing the battery not to charge. any idea or suggesstions.
Old Jan 3, 2006 | 02:50 PM
Patrick's Avatar
Default RE: Ground Point 96 disco please help!!!
run a new ground?
Old Jan 3, 2006 | 11:48 PM
Bait's Avatar
Your serpentine belt is routed incorrectly. It should do a 90 degree turn off the alternator, not run over the top of it.
Old Jan 4, 2006 | 12:16 AM
mikemeyer0's Avatar
if it is running and you pull the ground off your batt. then alt is working and belt is correct. Check the batt. cables for corrosion. they may be corroded inside and you can see it, you can check there resistance.
here is a belt diagram incase you need it though.
Old Jan 7, 2006 | 10:31 AM
Charlie L's Avatar
Hi Mike
Do you have the same diagram for a 99 Disco II with ACE? I want to replace my S belt.
Thanks
Old Jan 7, 2006 | 09:37 PM
mikemeyer0's Avatar
ORIGINAL: Charlie L
Hi Mike
Thanks
Sure
Old Jan 8, 2006 | 09:54 PM
Charlie L's Avatar
Thanks Mike
Is there also a diagram on what tensioner should be loosened first? It would be great to have this too.
I appreciate your help!
Old Jan 17, 2006 | 01:04 AM
yoeman's Avatar
Would you have a manual for the 96. I need to know how to enter my radio code although it may be to late because ive tried 3times and no luck
Old Jan 17, 2006 | 11:14 PM
mikemeyer0's Avatar
ORIGINAL: yoeman
let the radio sit with the key on for an hour at least, (radio will display code on it for an hour or so w/o any interruptions) the try the code again, you get 3 try's then you have to wait with power to it for at least an hour to try again. to enter the code you simply just enter the 5 digit code. If you have the wrong code go to the dealer with the vin # and ask for it, they will give it to you.
Old Jan 17, 2006 | 11:15 PM
mikemeyer0's Avatar
ORIGINAL: Charlie L
Thanks Mike
don't understand, just loosen the tensioner and remove belt.
MrHSE7
Feb 11, 2014 12:39 PM
csansoni
Dec 14, 2011 12:26 PM
RROJ
Jul 24, 2011 07:59 AM
kcirtap
Sep 26, 2007 09:39 AM
traffictech870
Mar 23, 2005 11:45 PM
