Hard Brakes...still
Old Aug 23, 2012 | 10:37 PM
lrsmith62's Avatar
Default Hard Brakes...still
Got a DII and it had very hard brakes...they do get better after being used some. Once it sits, they stiffen up again, only rolls to stop over several feet.
I put new pads on, new front rotors (haven't done rears yet). Fluid is topped off. No warning lights. Still feels the same. Truck has 52,000 miles on it.
Is this likely to be a booster problem or is there something else I can check?
thanks
Old Aug 23, 2012 | 11:12 PM
Racer X's Avatar
I'd disconnect the ABS kit to rule it out. If there's no change, start looking at the booster.
Old Aug 24, 2012 | 07:18 AM
ABS will not cause this problem. I would suggest you or a mechanic test for a bad booster and or master cylinder.
Old Aug 24, 2012 | 07:35 AM
lrsmith62's Avatar
I'm very mechanical generally....what's the best way to do this Mike? thanks
Old Aug 24, 2012 | 08:24 AM
PM me your number and lets talk about it.
johnnyjohnny
Sep 26, 2019 09:37 PM
Miss Rover
Jan 29, 2013 11:24 AM
FightOnUSC79
Nov 26, 2010 09:43 AM
pipjack
May 27, 2010 07:02 PM
meltdowndave
Jan 3, 2010 10:28 AM
