Hard to put gas into tank....
Old Jun 23, 2009 | 12:47 PM
Rover Curious's Avatar
I had this issue the first two times I filled up my truck at two different gas stations. I, like you, thought it was something to do with the truck. Tried a different gas station the third time and viola, problem gone. Been going to that gas station pretty much ever since, unless I'm out of town.
Old Jun 23, 2009 | 12:52 PM
lipadj46's Avatar
Tell me about it with the price of premium rising everyday it is getting hard to put gas in my Disco.
Old Jun 23, 2009 | 12:54 PM
RoverTCV8's Avatar
Originally Posted by Camdisco24
This happened at a different gas station?
Yes, this has happen at 3 different locations
Old Jun 23, 2009 | 02:46 PM
Your vent tube is clogged, I think you just need to replace it.
I too have had this problem but I went to a different gas station and no problem.
Old Jun 23, 2009 | 02:50 PM
Originally Posted by alpineclimber
...mostly the Sams Club (Cheap premium...) down the street from work...
You'll be sorry your using their cheap gas before you know it.
Pay the extra $.02 cents per gallon and get good gas, theirs will corbon up your engine...not to mention its prob stale.
Old Jul 7, 2009 | 10:06 AM
Landisara's Avatar
4th Gear
OMG (sorry for the valley girl response but...)
I have this same exact problem on my 01 Disco II!!!! I have to stand there and hold it every so gently with the trigger-thingy in a half pulled postion. I thought it was the station but I read here that others have the same problem. I've tried repositioning the nozzle because I thought that maybe air was getting in somehow. That didn't work.
Old Jul 7, 2009 | 11:53 AM
Rover Chris's Avatar
I have the same problem as well and have never noticed it in any other vehicle I have ever owned, so I always thought it is a combination of the 2. some stations may flow there fuel a little faster and the rover filler tube can only handle so much fuel so quickly?
I could only look at this problem with 1 of 2 solutions 1. get over it and plan for an extra minute while fueling up, or 2. get a different truck!
I still drive my rover!
Old Jul 7, 2009 | 11:57 AM
malmberg's Avatar
I have also had this problem before. In my situation the purge valve needed to be replaced. Now I can pump gas wherever I want. It is a simple fix if you only replace the valve and the top half of the line. It is more expensive than I remember but if you have to get a smog test you must have this to pass. The part is a charcoal canister purge valve (http://roverparts.com/Parts/WTV100150G.cfm) if this link doesn't work check at atlantic british.
Old Apr 18, 2021 | 11:32 AM
Samay Sy's Avatar
Default Evap system
Originally Posted by RoverTCV8
Ok, if you have made it this far, then you are curious about the topic.
I have a problem with filling up the gas tank. I get about 3 to 4 gallons into her and then it acts like the tank cannot hold anymore gas, and shuts the pump off. Yet, knowing that I still have a ways to go.
Can anyone tell me whats going on?
I have the feeling that it has something to do with the fuel canistor on the right fender well..
Welcome any and all comments.
John
Check your evap vent system check your vent tube from your vent solenoid see if any dirt or spider webs in or your canister is clogged.
Old Apr 18, 2021 | 09:15 PM
Xanthro's Avatar
Holy Necro Discoman!!
bamaboy473
Feb 15, 2013 01:40 PM
jfall
Jul 23, 2012 04:32 PM
tsam19
Freelander
Jul 28, 2011 09:50 PM
freelanderjames
Freelander
Dec 24, 2008 10:18 PM
theworks001
Dec 8, 2008 09:47 AM
