Hard to start... only sometimes. Runs great
Old 09-27-2019 | 09:15 AM
mollusc's Avatar
Originally Posted by CollieRover
Bad crank sensor won’t crank at all.
wrong. bad crank sensor won't fire at all, but will crank for as long as the battery has power.
  #22
sickws6's Avatar
Negative. engine will still turn over but not fire with a bad crank sensor, ignition won't initiate.
  #23
Old 09-27-2019 | 10:39 AM
JUKE179r's Avatar
@sickws6 ... What are your fault codes? Did you use a Bosch brand crankshaft Position sensor?
  #24
Old 09-27-2019 | 10:41 AM
sickws6's Avatar
No fault codes! And second time around I used a Bosch CPS.
  #25
Old 09-27-2019 | 12:13 PM
Red5's Avatar
If tapping the gas pedal has an effect, it could be and issue with the Throttle Position Sensor.
  #26
Old 09-27-2019 | 01:56 PM
sickws6's Avatar
Hmmm. Ill check that out. I don't have any other typical faulty TPS symptoms though.
  #27
Old 09-29-2019 | 09:21 PM
sickws6's Avatar
I'm thinking possibly clogged or leaking injector. I'll do an injector clean this week.
  #28
Old 10-01-2019 | 09:29 PM
sickws6's Avatar
Ran injector clean process. No change thus far. I might have a leaking injector.
mx5msm
04-13-2015 01:00 AM
TheGageinator
12-19-2014 01:40 PM
DSCVRY
10-23-2014 09:55 AM
shady milkman
10-03-2012 02:31 PM
AustinMiniMan
01-29-2010 01:20 PM
Quick Reply: Hard to start... only sometimes. Runs great
