Hard to start... only sometimes. Runs great
Old Sep 27, 2019 | 08:15 AM
  #21
mollusc's Avatar
Originally Posted by CollieRover
Bad crank sensor won’t crank at all.
wrong. bad crank sensor won't fire at all, but will crank for as long as the battery has power.
  #22
sickws6's Avatar
Negative. engine will still turn over but not fire with a bad crank sensor, ignition won't initiate.
Old Sep 27, 2019 | 09:39 AM
  #23
JUKE179r's Avatar
@sickws6 ... What are your fault codes? Did you use a Bosch brand crankshaft Position sensor?
Old Sep 27, 2019 | 09:41 AM
  #24
sickws6's Avatar
No fault codes! And second time around I used a Bosch CPS.
Old Sep 27, 2019 | 11:13 AM
  #25
Red5's Avatar
If tapping the gas pedal has an effect, it could be and issue with the Throttle Position Sensor.
Old Sep 27, 2019 | 12:56 PM
  #26
sickws6's Avatar
Hmmm. Ill check that out. I don't have any other typical faulty TPS symptoms though.
Old Sep 29, 2019 | 08:21 PM
  #27
sickws6's Avatar
I'm thinking possibly clogged or leaking injector. I'll do an injector clean this week.
Old Oct 1, 2019 | 08:29 PM
  #28
sickws6's Avatar
Ran injector clean process. No change thus far. I might have a leaking injector.
mx5msm
Apr 13, 2015 12:00 AM
TheGageinator
Dec 19, 2014 12:40 PM
DSCVRY
Oct 23, 2014 08:55 AM
shady milkman
Oct 3, 2012 01:31 PM
AustinMiniMan
Jan 29, 2010 12:20 PM
