Harmonic damper and crank rust?
Old Aug 8, 2022 | 01:01 AM
neuropathy's Avatar
Default Harmonic damper and crank rust?
Is this rust or something else that needs to be polished off before reassembling? I think the crank shaft had some light marks on it too - not sure if something got on it that caused that like brake cleaner that was on the gloves maybe. Any suggestions for cleaning it off each part, if that’s necessary? Do I need to use WD40 to make sure nothing rusts?
Old Aug 8, 2022 | 08:49 AM
Best4x4's Avatar
Use a little scotchbrite pad on it and spray some WD40 on it and call it good. None of that is going to effect anything in the long run as it's not a bearing surface.
Old Aug 8, 2022 | 11:17 AM
neuropathy's Avatar
Thanks! I’ll do that on both the harmonic damper and the crankshaft.
Aj6543
Mar 26, 2021 10:27 PM
redwhitekat
Jul 15, 2020 05:19 AM
Spencerfitch
Sep 2, 2010 08:51 PM
DooDer
Feb 17, 2010 12:31 PM
apcollin
Aug 23, 2008 08:01 PM
