Has anybody seen this ABS fault code?
"rear left corner valve power amplifier open circuit. fault logged"
I replaced the shuttle valves a few months ago and have been getting intermittent 3 amigos.
It's also showing a ride height sensor out of range but that is due to coil spring conversion.
Ok, thanks. A loose ground wire does make sense. I hit a bump in the road one time and the 3 amigos came on. However, other times they just came on randomly.
