Has anyone just used gasket seal for the upper intake mani?
Old May 6, 2012 | 01:55 PM
me 2's Avatar
Default Has anyone just used gasket seal for the upper intake mani?
I just did a head job and figured out that I didnt get a upper intake manifold gasket with the head gasket kit. I had tossed the old gaskets and assume I tossed the upper gasket as well. Can i just use gasket seal? Its Ultra Black RTV. Thanks
Attached Thumbnails Has anyone just used gasket seal for the upper intake mani?-gasket.jpg
Old May 6, 2012 | 02:04 PM
Discovery SE7's Avatar
I took one apart that someone used black gasket seal instead of using the actual gasket. It didn't work out too well. I think I did a video of the removal so I'll see if I can take a picture from the video and post it. It was basically like there was no gasket at all.
Old May 6, 2012 | 02:07 PM
jafir's Avatar
It's pretty cheap. If it were me, I'd just order one and do it right.
Land Rover parts, spares, Land Rover accessories - Search results for ERR6621
Old May 6, 2012 | 03:15 PM
These are some pictures from the video I took. These were taken right after lifting the upper intake manifold. Nothing was scraped off. This is all that was left after someone used a liquid gasket seal instead of the actual gasket.
http://www.flickr.com/photos/tauruspt145/7149720435/http://www.flickr.com/photos/tauruspt145/7149720435/
http://www.flickr.com/photos/tauruspt145/7003630786/http://www.flickr.com/photos/tauruspt145/7003630786/
Old May 7, 2012 | 08:17 AM
me 2's Avatar
Default stuff
Wow, your right, nothing there. I found some for around $30 so will go ahead and order one. Thanks for the info and pics
Old May 7, 2012 | 08:55 AM
jafir's Avatar
It's $9 at the link I posted.
Old May 8, 2012 | 08:08 AM
me 2's Avatar
Default stuff
Just saw the link, thank you.
Old May 8, 2012 | 12:57 PM
jfall's Avatar
Don't cheap out.
Use a real gasket.
The gasket maker stuff is $6 anyway.
You almost could buy raw gasket paper and cut your own.
I have seen a hybrid metal gasket in there.
Metal with gasket material on top and bottom.
dougn
Dec 7, 2014 08:51 PM
s10lowrider1994
Jun 21, 2014 09:44 PM
certguy12
Jan 30, 2013 10:42 AM
me 2
May 12, 2012 09:32 PM
