Quick head job question about intake mani
Old May 3, 2012 | 06:08 PM
me 2's Avatar
Default Quick head job question about intake mani
Just getting the motor back together after a head job and kinda confused on the placement of the intake manifold. Is gasket sealant needed on both sides of the intake manifold gasket or just the bottom of the gasket? Thanks
Old May 3, 2012 | 07:57 PM
Please see attached page from RAVE. Will certainly need sealant in notches.
File Type: pdf
Old May 4, 2012 | 05:30 AM
drowssap's Avatar
i did both sides
Old May 4, 2012 | 06:27 AM
ptschram's Avatar
I use Right-Stuff on the end clamp seals and high-tack on both sides of the gasket proper.
Never had a come-back on one yet.
(scurries about looking for something to "touch wood")
Old May 4, 2012 | 07:36 AM
me 2's Avatar
Default stuff
So the illustration states only under the intake gasket but you guys do both sides right?
Old May 12, 2012 | 09:32 PM
Lukefernando's Avatar
Thanks. I am bit confused about the torquing sequence. I would like someone to correct me if I am wrong.
1.Initially, tighten bolts numbered 1, 4, 9 and
12 in numerical order to 5 Nm (4 lbf.ft).
2. Then tighten to 8 lbf.ft from bolt 1 to 12
3. then the final tighten to 38 lbf ft from bolt 1 to 12
Is this sequence described above correct or am I missing anything.
Also what type of sealant (brand) I should purchase?
USAroverman
May 31, 2015 05:20 PM
me 2
May 8, 2012 12:57 PM
ShortTom
Nov 4, 2010 08:23 AM
icyhot201
Aug 16, 2010 07:24 PM
endneu913
Nov 3, 2007 03:46 PM
