Has anyone made the tool for removing the radio?
Old Dec 20, 2011 | 09:15 AM
toad2's Avatar
Default Has anyone made the tool for removing the radio?
The tool # is 86-006 in the rave manual. If i had the dimensions i would make it and take out my deck, or maybe someone has a better/easier way of unhooking the clips. Thanks in advance.
Old Dec 20, 2011 | 09:33 AM
drowssap's Avatar
some say you can do it with a pair of small screwdrivers, the tool can be got at any audio or most auto parts stores for a few dollars. I stop at a audio place and told them it had to be removed to change the bulds in the heater control, it was a freebie I thru the kid $10 for coffee.
Old Dec 20, 2011 | 09:35 AM
cfp_ivan's Avatar
I used 2 paper clips, the jumbo ones. It worked!
Old Dec 20, 2011 | 09:52 AM
photocrimes's Avatar
Use the metal support out of a hanging file folder cut in half. It mimics the tool perfectly.
Old Dec 20, 2011 | 10:50 AM
russburcham's Avatar
What Photocrimes said! then tape the ends that you grasp
Old Dec 20, 2011 | 11:59 AM
yloDiscoII's Avatar
X2, that's what I did. It's a little finicky to get it to work, but FREE if you have access to one of those hanging files.
Old Dec 20, 2011 | 02:37 PM
toad2's Avatar
thanks guys, now to find a hanging file!
Old Dec 20, 2011 | 04:17 PM
atancreti's Avatar
Yes, Napa sells it. Its called a ford radio removal tool. number 7575. At least that works for my DI.
Old Dec 20, 2011 | 04:36 PM
lordmorpheus's Avatar
D2s have two flat slots near the top of the radio head, unlike the D1 apparently.
Old Dec 20, 2011 | 05:53 PM
Waterfowl's Avatar
What radio have you decided to install?
