has anyone smashed in their gas tank before?? fixes??
Wifey "aka" (rookie spotter) was spotting me one day while backing up, and froze when she was supposed to stop me from smashing in my gas tank.... It only fills up to 10.000 gallons/ half-tank when at the pump and has no leaks... it smashed in at the center where the metal skid gaurd is... The tank is plastic but was protected by the metal taking the blow.... If I take off the tank, un bend the metal skid and seperate from the tank, then my question is will the tank be salvageble, in other words being that its plastic and bent with no holes, can it be bent back out to normal without cracking.... maybe carefully heat it up to non dangerous level and push it down from the inside out... Or..... Or..... Or....
just running through my options, will probably get started on fixing this in the next month or two as it is not my daily driver.... still gets barely 100+ miles but is enough to stall the repair for a while....
2000 disco II
2000 disco II
IMHO, from me pulling a used fuel pump at the salvage yard where tanks get damaged by vehicle moving fork lifts, you may find that pump assembly has also been deformed by this close encounter of the grantite kind.... Not very much clearance on the pump assembly even on a new tank.
Discovery II Aluminum Fuel Tank Skidplate | Columbia Overland
yep smack the skid plate smooth, the tank should pop back to shape. Aplying heat to the gas tank is a good idear if you want to burn your truck and house down.if your tank does go back to whear it should be check for cracks, is the dent turns white more then likley you will need a new tank.As for the fuel pump if the sender unit works (fuel guage) and the housing isnt cracked you should be ok.If you damaged your pump you can buy just the pump.If so check back mon I am putting a new pump motor in my tank, and I will let you know how it goes.Good luck!
On father's day some idiot in our area decided to torch out the bolts on his gas tank.
the tank exploded and gas went on the house and burned it down.
The truck was ten feet from the house and yet it still burned down.
Oh and some idiot burned down a land rover dealership by using an electric drill to drill out a disco one tank. We were doing fuel tank recalls at the time and he decided to use an electric drill to empty the tank quicker. Well apparently what caused the spark wasn't the drill, he wasn't grounded and when he went to flick a piece of plastic left over it caused a electrical discharged which promptly put him on fire along with the truck. The twelve vehicles in the shop including a XK convertible with the top down was ruined by the water sprinklers and the shop closed permanently and those souls were put out of business.
I have seen the pics of the shop and the fire. not pretty at all.
