Have 2000 Discovery Series II
I recently acquired a 2000 Land Rover Series II. It has been sitting for a few years. I have replaced the gas, oil, and battery. The lights and electrical system seem to be working. When I try to start the engine the oil and battery indicators light up but will not turn over. Any suggestions and ideas on what I should do in order to get it started?
Nothing OBD2 wise is gonna tell you if you have a bad starter. A meter, and a helper is the quickest way. Slap the meter on the small lead + and then to ground with the - lead on meter. Have a helper turn the key. You should get 12v + when the key is turned. If you do the vehicle is doing everything properly but the solenoid is out on your starter. A new starter should get you going. If you don't have 12v + when the ignition is turned you either have a bad fuse, or possibly an issue with the ignition switch or electronics.
DISCOLIVES
03-31-2008 01:05 PM
VSR
12-30-2006 10:03 PM
