Hawk eye and scanguage temps
Old Jan 29, 2011 | 06:02 PM
Rover Rebel's Avatar
Default Hawk eye and scanguage temps
I have a scanguage2 to keep close watch on coolant temp. I had access to a hawk eye today and the temp readings are very different. When my scanguage said 215 the hawk eye said 105.50. I know it was warmer because of the condenser fan was running. Can someone explain what's different. Thanks
Old Jan 29, 2011 | 06:13 PM
Because the Hawk Eye is set to Celsius.
Old Jan 29, 2011 | 07:42 PM
lipadj46's Avatar
You have a british vehicle and it thinks in the metric system. Glad you got the scanner OK! Also 105.5C is pretty hot, I have only seen my truck get up to 105 once in the summer. Was that during Idle after a long drive?
Old Jan 29, 2011 | 08:06 PM
Thanks for the replys, that makes since to me now and yes that was idle for awhile. I thought that was to hot though. It does great going down the road but just sitting it wants to heat up on me. I thinks it's air in the system I hope. The head gaskets, thermostat, coolant cap, and flushed heater core all have been done but it's been hard for me to bleed this thing for some reason, just the passed few days have got te heat to work correctly. Any suggestions, thanks guys.
Old Jan 29, 2011 | 08:24 PM
Keep in mind that the DII re-routes the coolant from the radiator to the heater core while at idle, so it will run hot at idle because the heater core cannot remove as much heat as the radiator.
As long as the temp gauge reads normal dont worry about it.
Old Jan 29, 2011 | 08:34 PM
Thanks spike for replying back. I might just have to flush the radiator it's starting to worry me a little. I appreciate it
hilltoppersx
May 1, 2013 12:06 PM
csp33
Oct 16, 2011 10:59 PM
Disco_Fever
Apr 28, 2009 04:21 PM
rrhyne
Nov 21, 2008 03:24 AM
Scanner
May 17, 2008 11:01 PM
