Hayden fan clutch & original fan?
Old Jul 24, 2022 | 04:58 PM
Toms's Avatar
Originally Posted by acg
Do you have something like an Ultragauge or Scangauge OBD reader to monitor your coolant temp? I suggest getting one so that you have a baseline of your coolant temp.
Then read this to determine if the Hayden clutch and Doorman fan blade is necessary:
https://landroverforums.com/forum/di...-107475/page2/
yes friend I have an ultra scangauge and out there monitoring I haven't seen it in more than 194 but I still don't use it daily but a few miles a week... and an electric auto meter gauge to monitor oil pressure
Old Jul 24, 2022 | 05:00 PM
Toms's Avatar
How did it go or what configuration do you currently have?
Old Jul 24, 2022 | 08:42 PM
acg's Avatar
acg
I am the OP of this thread that I previously posted:
See post #11:
A quick update with the 2991 fan clutch...simply awesome. 3 days of offroading. Climbed to 2000-metres. Hardly broke a sweat. 174F to 179F pretty much all day. Went up to 188F after a long climb. Then settled down quickly to 179F. The fan hub does sound like a jet turbine engine when under load though. But no worries at my end to have the cooling peace of mind.
Old Jul 24, 2022 | 10:43 PM
Toms's Avatar
See post #11:
It is incredible that it works so well… if that is what I am looking for since the problem with these trucks from what I have been able to investigate is the high temperatures…. I am going to make that small investment, the sound is what worries me the least, I also thought of electric ones but that would be more cumbersome for me
Old Aug 12, 2022 | 08:44 PM
Toms's Avatar
Default Test result
See post #11:
Well, I'm here to share my experience, after changing the fan and blade recommended Hayden 2991 fan and Dorman 620-112, with bypass thermostat 180• new water pump, new radiator, new nissens coolant, zerex G05. and today i went out and did about 100 miles with the air on and the temperature stayed 180 to 188 and i stopped for about 10 min and it went up to 200. i live in florida outside temperature 91• i think something is wrong. that fan sounds like a turbine
what could be happening or what could be wrong? oil pressure relatin 25 psi at 2000 rpm 50psi
help…
Old Aug 13, 2022 | 12:29 AM
Richard Gallant's Avatar
@Toms yup that combo is loud but it works - after a long hiway drive when you stop at a light the temp will go up, if the air is on even more. Ac seems to add about 6 to 7 degrees to engine temp on average.
Old Aug 13, 2022 | 05:42 AM
mln01's Avatar
what could be happening or what could be wrong? ...
help…
I'm not seeing a problem here. What do you not like? The temps are fine.
Old Aug 13, 2022 | 08:21 AM
acg's Avatar
acg
help…
The temps look fine to me. The 2991 is the severe duty version of the fan and it does cycle more often and does sound like a turbine. But it does provide more cooling for the radiator.
https://www.haydenauto.com/en/produc...-types/thermal
The temps will climb slowly if you truck is not moving and idling. I was getting 179F to 183F when moving (ambient temps around 85F). It will climb to the 188F to 197F range when I am idling for about 10 mins with the aircon on (aircon running around 64F to 68F).
Old Aug 13, 2022 | 08:27 AM
Toms's Avatar
help…
Thanks guys, I thought I still had something bad out there. because I have seen here that the temperatures work at a maximum of 180 but I don't know under what parameter of conditions, I am going to try with the original fan to see the difference. another question instead should I consume more gas with the 2991?
Old Aug 13, 2022 | 08:29 AM
Toms's Avatar
if I was in doubt if the temperature ranges were right. Thank you
