HD Fan rubbing on top shroud
I put the new HD fan and clutch on a couple of weeks ago and the fan rubs the top shroud when under load acceleration. Has at least an inch gap when not running. I installed the parts numbers listed many times on the forum but have not found anyone else mentioning this issue.
it wore about roughly a 1/4" groove in the shroud but no damage done to the fan. I took the top shroud off and used a dremel flap disc to thin the area that was rubbing and will test it out tomorrow.
Anybody have this issue with this mod?
could this be my motor mounts? I could see that could be it but have no idea how to check them.
First verify the lower shroud and the radiator itself are held into place properly. If all that is good I'd have the engine & transmission mounts checked or replaced.
That shop that said the parts didn't fit = totally clueless and had no idea what they were talking about!!!
I have ran this setup since 2014 on 3 D2's from 99 to 04 and if the radiator is supported properly, the lower shroud is mounted properly into the lower edge of the radiator, then yep that engine/trans/TC is moving around and causing it to rub no doubt about it.
I will put my LR reputation on the line when I say the Doorman 620-112 fan and Hayden 2991 fan clutch work on any 99-04 D2 or even an 00-02 P38 for that matter!
